I've been testing my chlorine daily and I've been following the Poolmath calculator and adding roughly 2 gallons of bleach a day. Even though I've been adding bleach daily, are pool is in direct sunlight most of the day, so I know it burns off. Our CYA is testing as 40. Here's my problem. The pool looks great from above. You can see the bottom from the deck or while in the pool. However, once you dive under the water, it appears very cloudy. Here's my question - what is causing this to happen? When we first started getting in the pool after it was filled, my husband and I could see from one side of the pool to the other; now we are lucky to see 4 feet in front of us. However, the pool looks great from above. I have been adding chlorine to attempt to keep a FC level of 6.0. What should I do next?
