Relatively new pool owner here, using the BBB method for a 29K gallon vinyl pool. The pool was looking great prior to the holiday weekend. The water was clear and well balanced, I had added some DE to our sand filter, vacuumed it several times (with our Doheny Discovery), etc.
Over the holiday weekend, we had a light swimmer load - 2 kids and 3 adults. After the weekend, I backwashed the filter, mostly to remove the DE, as it was impacting my pump flow rates and didn't make a noticeable difference in water clarity (to my eyes, at least).
Since the weekend, I've noticed two things:
1. On 7/6, a little bit of algae growing on the pool walls. Not much, and seems to be be better now, but there is still some there. When brushed, it appears greenish-brown in the water.
2. In generally, the water is looking a bit cloudy/matte. Not terrible by any measure, but not the crystal clear, sparkly water like it was before the holiday weekend.
Here are my recent test results, using the TF-100 kit:
Any tips to help eliminate the algae and get back to beautiful water?
Thanks.
Date | Temp | FC | CC | TC | CYA | TA | pH | Added after testing |
6/30/2017 | -- | 1.5 | 0 | 1.5 | -- | -- | 7.8 | 2 jugs bleach |
7/2/2017 | 81 | 2 | 0.5 | 2.5 | 50 | 100 | 7.8 | 2 jugs bleach |
7/6/2017 | -- | 2 | 0 | 2 | 50 | 110 | 8 | 3 jugs bleach (b/c of algae), 1/2 gal muriatic acid |
7/8/2017 | -- | 5.5 | 0.5 | 6 | 50 | 110 | 7.5 | none |
Thanks.
