I just bought a Warrior SI from Marina Pool and Spa. After having it for almost a week now, it seems as if the cleaner has a hard time turning as it doesn't actually use the treads to turn - it sort of backs up and hops into the turns, which is not successful most of the time. It seeminly ends up cleaning the same area (the deep end) over and over instead of making its way around the pool, no matter where I start it off. We have a rectangle shaped 30 X 15 in ground with mini pebble finish so I don't know if the shape or the surface is contributing to the problem. There is a bench and steps on one end of the pool and a corner step and short bench on the deep end. The pool is 3.5 ft in the shallow end and 6 ft in the deep.
Is this just the way it is going to be or did I get a bum model?
