Hi everyone. So we have a 32,000 gallon free form pool. See image:
The landscaped area in red has 3 spouts for waterfalls embedded in the rock that go into the pool. I want to completely remove the landscaped area and add an inground hot tub/spa. However, I don't want some dinky 6 person round seater and because my pool is free-form, I don't want some giant rectangle sitting next to it - it would be awkward.
A few pool builders have suggested simply building a "mini pool" and putting a vinyl liner on it, building seats and putting in jets. I don't anticipate keeping the water at 105 degrees all the time, if ever, but more or less use it as a "warmer area" to be in an extra month or two before normal pool season here in NJ And perhaps another 1-1.5 months at the end of the season.
My question is this:
(1) Are there any "Drop-in" prefabricated units that would be appropriate for this area that are larger?
(2) Is using a vinyl liner for this idea ok? Obviously you don't really see too many vinyl liner hot-tubs... i assume there is a reason, but given my circumstances, would it be acceptable? Will I face any issues?
(3) Noting that my pool equipment is basically in the top right (you cant see it, but its under the trees in the top right) and thus lines will obviously have to be dug, but not insanely far - what are some ballparks you might expect this job to cost? Is $10k possible? Is $15k? Am I looking at $30k minimum?
(4) I've seen some people, especially the guy from texas, embed nice small water slides as part of the rock aesthetics. I was thinking of a small slide that starts on the right hand side of the to be built hot tub/spa, wraps around slightly and then goes into the bottom portion of the pool which is the deep end. Any thoughts on that?
Basically looking for opinions on whether this is a
(A) "sure anything can be done for a price" type project
VS
(B) "yeah, i've seen people do this before. It's not $5k, but you could do it right for $10-$15k"
and
(C) Vinyl hot tub? No way you are crazy
VS
(D) Yeah i've seen people build mini-like pools that were giant hot tubs and use vinyl before.
....I welcome all thoughts, criticisms and feedback openly! Thank you!
VS
and
VS
