new member here, I thank you all in advance for any help you can give me. I had a new gunite 31,000 salt pool installed last year with colored plaster. upon opening this year, when I felt the bottom on one of the steps, it felt like sandpaper. I rubbed it and some clearish crystals rubbed off but most of it is stuck. the rest of the pool is the same way. I have been running an automatic cleaner which has been filling its bag with this stuff in about an hour. I have filled about 6 bags so far. I am wondering if this stuff will disintegrate once my chemistry is back in check or if I will have to actually scrub this stuff off. last year I was running these numbers:
ph 7.8-8 ...was adding acid every 2 days
ta 110-120
ch 330
cya 85
chlorine 3-4
upon opening this year ph was off the scale. have since adding 2 gallons and its at 8 now. im adding more tonight
ta was 140, then 120, now 92. (went down with the acid) first 2 tests I did myself, 3rd was a pool store. i would bet if i did it myself, it wouldn't be 92 and would be around 100.
cya 76
ch: i came up with 275, store came up with 220. if iit matters, 1 gallon of acid was added in between.
salt: 2600, added 1 bag. then 2800, added another. should be at 3000 now.
thanks again
anthony
ta 110-120
ch 330
cya 85
chlorine 3-4
cya 76
thanks again
anthony
