Well there is the other train of thought too. Maybe your drops were too small making it less yellow. Good for future knowledge either way, but *anytime* a test comes back wonky, do it again and slow it down. We are all far too occupied with everything else that it’s way too easy to squirt and not drop. The literal 5 seconds saved per test by being in a hurry could be the difference between TFP clear and yelling like Shrek to get out of your swamp.
Bottle goes fully upside down and gentle soft squeeze to let gravity make perfect, repeatable, drops.
As a side note, I rarely used my block FC test and the bottle was firmer from less use. Maybe it needs some more breaking in. Or hack it to modify it to how it’s working for you. If you can get multiple tests that need a 6th drop to match the expected FC of the powder test, then use 6 drops until that doesn’t match anymore.
