Why not replace the pump?
If you want to rack your brains on the details of stray inductance and capacitance in transformer analysis, see here - http://coefs.uncc.edu/mnoras/files/2013/03/Transformer-and-Inductor-Design-Handbook_Chapter_17.pdf
Your problems could simply be a poorly constructed motor, possibly just a one-off bad motor where there's some defect in the way the motor was built giving it too much stray capacitance in the windings. I believe these VSPs all have multiple windings in them that get turned on by the power supply at different RPMs along with the usual variable-frequency power applied. This way, the most efficient combination of drive frequency and motor windings can be utilized. The problem is, with multiple windings comes the possibility of stray inductance and capacitance across the different windings as well as within the windings themselves. When the VFD switches on and off (it's just a square-wave drive voltage), the leading and trailing edges of the square-wave can have significant voltage/current spikes show up as the stray parasitics charge & discharge. Unless a great deal of care is taken in how the coils are wound (special winging patterns) and how the wire sizes and insulation is specified, one can build up a large degree of stray parasitics.
So, you may have gotten the one bad luck motor out of the factory that probably passed the limited quality control measures but fails in the field. I'd take your PB up on the offer of a complete pump replacement as you should not have to futz around with your pool pump like this. It's just unacceptable and you have more than proven that you have a real problem and that you have exhausted all reasonable on-site fixes.
Thanks Matt.
I'm not sure how far deep you read into the thread, but the originally installed pump [Oct 2014] was replaced somewhere in the late Jan 2015 - early March 2015 timeframe. When the original breakers were flipping like mad, a tech came out and wanted to examine the pumps wiring. The wiring cover on the pump has a main screw you tighten to secure the cover. Well, when he went to loosen it, the cover just came off, and there was heavy oxidation of all the wiring/even some water in it, so the whole pump was replaced...7-9 months later, the breakers flipped and it turned out to be a locked-up motor, so the motor was replaced on the replacement pump...since then, the controller on this same pump has been replaced twice, and the breakers have flipped twice since the last controller was replaced [Dec 15-20[.
A master electrician said [from info provided, no onsite testing or examination] that w all those pump and parts replaced, he believed it to possibly be the wiring btw pump & breaker or something on the buss board, or you have just received one crappy pump and pump part after another...
Since the breakers that trip [two diff ones of the same make.model (Sq-D, DP 20amp GFCI breakers)] seem to follow where the pump is placed on it, the pump seems to be the problem. But constant in the equation is the wiring [never been checked]. So, w/ that being said, and many of the other fine people that have posted on here, I have come to this potential resolution w one question:
1. Replace the entire pump as manufacturer has suggested
2. Examine and or replace wiring btw pump and breaker/panel
3. Question, do I ask to replace the breakers that have been flipping? When I want in to test the torque of the wires tighten into the breaker, the screws were tight, but there seemed to be some play or looseness of the what the screws were tightening onto w.in the 20amp breaker
4. Increase the speed/RPM's of Spd2 from 1390RPMS to 1500-1600 where the breaker always seems to flip, which it has done in the last 5-6 trips over last 5-6 weeks [all during even amp draw runtime, never on start-up or during an RPM realtime increase or decrease].
At this point, I really do not care what the actual fix is if it 1 or all 4 of the above, but I just need to let you guys focus on other posts bc I know this is prob starting to flip a bunch of our mental breakers...at least it is for me.
Again, I cannot thank all of you enough for your continued feedback and help - I hope I can soon help others too - tstex
