Hello to all,
History of system:
Equipment installed Oct 2014, Equipment activated Jan 2015, the Hayward 3 HP EcoStar VSP pump tripped the breakers on and off for 3-5 weeks. Went from 3 slots of breakers to all 6 slots of breakers in panel. Each pump [VSP and Super II scupper pump [were ea on their own breaker. And, we went from the Siemens QF220 GFCI breakers to the equivalent SQ-D type breakers. Not only were all the breakers changed out, but Hayward also installed a new identical pump too.
All operated ok for 12-14 months [June 2016], then the breaker w the VSP tripped. The motor on the 2nd VSP was bad and was replaced. In early Dec 2106, 2 weeks ago, the breaker on the VSP tripped. Hayward Rep came out and moved the VSP to another breaker, and the Heater and Blower were moved to the breaker than just tripped. Just this morning, the breaker that the VSP was moved to, now tripped. The breaker that tripped 2 weeks ago now w the Heater and Blower, has not tripped. The Hayward Rep is coming back out tomorrow or Friday.
I wanted to know is this typical of VSP and 220 GFCI double poled breakers, or is something going on here? I am very concerned bc all has been covered under warranty, but after 3 yrs, if this continues, this will be very costly. So, I looking for immediate possible solutions. And, what do I need to prepare for or say to Hayward in the future?
The Hayward Rep/tech has been great, so as the Hayward local Mgr. They always respond, but the future concerns me. We’ve also had 2 pool LED lights replaced and on Spa LED light replaced too.
I really would appreciate any and all valid insight and technical support.
********** UPDATE**********
The Hayward tech came out Thursday afternoon and replaced the Drive on the 3400VSP for the second time. well, the breaker that feeds the VSP tripped again today. This is the main breaker bar, not the GFCI. It tripped during the time pump was operating at 1380RPMs, which mean it was drawing low amps and not in a start-up mode...the inside remote was flashing "CHECK SYSTEM" w the pump/filter icon lit, but no water flowing in the pool, and as noted, the breaker was tripped.
I am all ears if anyone has any suggestions on what to do ??
Regards, tstex
History of system:
Regards, tstex
