So I have a single speed pool pump, it's a very loud and fairly old 2.25 HP Max-e-glas. It likely has had at least 3 motors on it, the last I replaced myself. My plumbing is all 2" except my cleaner pipe, that's 1.5" and the pool is very large.
So I am looking to replace it with a VS motor or motor pump combo and also run some automation.
So If I keep my Max e glas I won't have to rework the pump connections so that's a plus but I will need to upgrade the impeller for about $50, no biggie.
The two VS motor options I have
Century V-Green 2.7hp with a square flange adapter at about $650 with an automation adapter for an additional $180 so about $880 for 2.7hp (not interested in cloud control option)
OR
Affinity AVSS3, no flange adapter needed 3hp pump for about $560 with EZ-COMM automation adapter at $130 so $740 for 3HP
The features and capability seems to be almost exactly the same between these two motors. 4 speeds, rs-485, freeze protection etc.
There is MUCH more info about the V-Green than the Affinity with the research I have done. So I am inclined to go with the V-Green HOWEVER, I also have a 3/4hp booster pump to run my polaris 280 cleaner. If it's possible to pull the booster pump out of the mix and use the Affinity 3HP pump alone to do everything then I am inclined to do that.
Last option, quit screwing around and just buy a new 3HP pentair or hayward for 1200-1400 and has 8 speeds plus well known automation.
Help me pull the trigger on what to buy.
OR
