Well it has been months in the planning, quotes from 3 companies and we finally have the basics selected. The wife was more proactive in the decision than I was. I have taken plenty of pre-build pictures. We just had some trees pulled to so we wont need the loggers back there after the build, and yeah, more sun. Plenty of great reading here so thanks! The entire process has been more expensive than anticipated as we just bought a new home that was 30 years old but it got us out of suburbia. One main question I have, the builder does not seemed too concerned with is water drainage. The pool will be the drop in shell about 15x30 (more specifics will follow). After the December - January being so wet we had some obnoxious water build up in our crawl space, and the pool will be behind the house at a lower elevation but I fear the pool dig may hit the water table. The builder says they will simply make a sump pump drain under it and it should not be an issue. I hope he is right.
Does any one have drainage guidance, questions to ask that might prevent bad surprises?
Additionally, the back yard is mainly clay covered with moss and water sits in the back yard. We have a landscaper that will be building a dry bed to channel the water away from the house and pool area and I feel pretty good about the entire process so far. Again, pictures to come, I know it is hard to get a good visual. I just can't connect my phone to my work computer.
