Good evening,
I'm in the process of winterizing my 24' above ground pool and noticed a couple things I'd like to address with the liner.
1. On a small section, probably 4' wide, the liner is slightly pulled away from the wall towards the top. So it's attached at the top and bottom still, but a portion of it is a little bit off the wall. I tried to get a photo of this, though it doesn't show up great. I've thought a lot about it, and I just can't figure out how it happened. What causes this, and is it possible to fix?
2. I think this is less concerning, but there are a few wrinkles on the wall near the skimmer and return jet. Any harm in leaving these?
Thanks!
Thanks!
