Very low cya
May 28, 2018
56
IL
I tested the CYA levels in my pool. I filled the cylinder completely to the top and could still see the black dot. What is the best method for adding stabilizer?
I am needing to start the SLAM process.
Solid/granular cyanuric acid (CYA) should be placed in a sock and the sock put in the skimmer basket or suspended in front of a pool return. After adding CYA you should leave the pump running for 24 hours and not backwash/clean the filter for a week. Squeezing the sock periodically will help it to dissolve faster. Test and dose chemicals in your pool assuming the amount of CYA added is in the pool according to Poolmath. CYA can be tested the day after it is fully dissolved from the sock.
