Hello...
Until you get your TF-100, please pull up your FC level to target level. IMO, in the meantime, add some bleach to your pool (The plain stuff - no splashless, scents, or polymers. No Clorox or cloromax - no additives). Add about a half a gallon of 10% liquid chlorine until you get your kit. That will add close to 5 ppm FC per day.
Your CYA is pretty high too. From this
link, there isn't even an FC target level for a CYA above 80 (SWCG Pool). Thus, please drain your pool. For instance, if your CYA is at 100, then you'll need to drain at least 60% of your pool water with new water. This will get you down to a CYA of at least 40. The reason I say this is because from your note above, it looks like you're going to have to SLAM your pool and SLAMing an outdoor pool is most effective when CYA is around 30 to 40. With a CYA of 100, please replace your pool water with fresh water and bring your CYA down to 30 - 40 before you start to the SLAM. Note: wait for your kit comes in before you begin the SLAM process. In the mean time again, add some bleach to your pool (The plain stuff - no splashless, scents, or polymers. No Clorox or cloromax - no additives). Add about a half a gallon of 10% liquid chlorine until you get your kit. That will add close to 5 ppm FC per day.
Please keep us posted. If you can send pictures of your pool now that would be great too.
