You listed your tc levels with the oto test. (It only measures tc to 5ppm)
You should be using the fas/dpd test for the slam. It accurately measures fc & cc separately up to 50ppm. So stick with that.
It can be frustrating to keep going but those potions/methods you mentioned may somewhat clear things up initially but aren’t truly eradicating the algae so it returns along with having to deal with the long term side effects of said various potions/products.
The
SLAM Process when followed as prescribed does work & If the proper fc/cya ratio is maintained thereafter there shouldn’t be a need to ever do it again. The slam process is set up the way it is to eradicate algae effectively & thoroughly (& prove its gone) without causing damage to surfaces, equipment, or swimmers in the process. It’s not an overnight miracle or a one & done addition of chlorine.
If you choose to proceed,
Lets also be certain of your cya level as it can be a tricky test to master. If the dot dissapears between two values be sure to round up & chlorinate accordingly.
Cyanuric acid (CYA) is the chemical name for the product commonly called “pool water stabilizer” … Read more…
www.troublefreepool.com
Can you post some pics of what you’re describing as mustard algae?
Is there pollen/dust on other outdoor surfaces- cars, patio etc?
A note:
The test kits we recommend are for a reason as they contain certain tests that other kits do not. Titration tests are the most reliable & affordable tests available for accurate home water testing. They are simply far superior to guess strips.
The tf100 kit is no different than the Taylor k2006 in the tests it provides except it costs less per test when you account for the extra reagents it contains. It is more equivalent to the Taylor k2006c in that respect which costs much more. They both use all Taylor reagents. If something better comes along that checks all the boxes you can bet it will become the recommended method here, until then in the US those are the recommendations.
