I have a Pentair IntellifloXF. I currently run it at 2900 RPM for about 10 hours a day (9am-7pm). I have a raised hot tub with a water spout/fall that I want to have the proper flow as well as circulate the pool. I was considering running the pump at a lower setting, maybe at 1000 RPM, for a few hours after 7pm just to keep the pool circulating. The water spout/fall would only trickle over at that rate but that late in the evening it doesn't matter. Any thoughts or inputs on what you guys do? Thanks.
