I have a single speed pump and am trying to figure out how to position my manual valves by minimizing spillover as much as possible.
The return side has pool jets, spa fountain (which is not hooked up, just a jet in the bottom of the spa), and spa jets. During normal operation I have been running the pool jets and spa fountain wide open with the spa jets closed. This has a pressure when the filters are clean of around 12psi. I have been experimenting with closing the spa fountain to only let about 20% of the water through and the rest going to the pool jets. When I do this the pressure is anywhere from 17-20 psi. My question is am I putting to much wear and tear on the plumbing and pump, long term, by minimizing the spillover? Should I just allow the spa fountain to continue wide open and not worry about the ph rise?
Thanks
Thanks
