Hello, all.
After years of paying a pool guy $100/mo my sister has asked me to take over (the maintenance, not the paying).
I've replaced the booster pump and the majority of the parts in her Pentair CC200 and everything still works so I got that going for me, which is good.
Bought a K-2006 test kit and have just used it for the first time. I'm actually doing everything for the first time - zero experience with pool maintenance.
The plan is to ditch the chlorine pucks and move to the TFPC method.
For the sake of brevity, it's a rectangular 8000 gallon IG pool, Sta-Rite P6E6D filter pump, Polaris PB4SQ booster pump, Polaris 280, and Pentair CC200. If my first tests are correct the CYA level is over 200.
For the sake of detail, I've been documenting my every move as I embark on this journey to learn enough to maintain this simple pool.
Notes and images from my first test with the K-2006 can be seen here.
I'm hoping to find out:
Apologies for the external links instead of posting images here. Figured I'd provide the bandwidth and storage. Please let me know if posting everything here is the preferred method and I'll be sure to go that route next time.
Thanks!
Mark
- if I made any mistakes in my first test.
- if my CYA readings are correct, what's the best way to deal with it.
- The pool store has told my sister the CYA level is 100 and she should drain it 1 foot, refill and retest.
- my first thought is to drain most of the pool and go from there (assuming CYA is actually over 200).
Thanks!
Mark
