vacuum to waste with cartridge filter (need plumbing advise)
jeffreymlewis
0
8
Walnut Creek, CA, USA
Yesterday I got a new Intelliflo VS pump, and asked the tech to replace my regular 5/8" garden hose spigot with a 3-way valve so I can, "vacuum to waste." Perhaps there was a mis-communication, because this is what I got,
I'm no genius, but I'm pretty sure I can't simply attach a hose to this setup, lest it be blown into my neighbor's yard.
Can anyone give advise on what I need to complete this job? Perhaps glue some 2" PVC into this reducer and clamp on one of those blue backwash hoses? (More elegant solutions welcomed!)
There is about 75'-100' between my pump and the sewer lateral.
Thanks in advance for you help,
Jeffrey
Re: vacuum to waste with cartridge filter (need plumbing adv
You just have to add a piece of PVC pipe and then a fitting to whatever type of hose you plan to use .... or just spray water all over the place ;)
Pardon me, but I see the valve above the pump, and a big ole hole, but I don't see a pipe leading towards, um, a filter. :wink:
Anyway, assuming it's just not visible in this photo, I'd say yes, you need to do exactly as you imagine.
We were lucky, we were able to access a bathroom drain/vent only several feet away and plumbed the drain-to-waste from the pool directly into the house drainage system.
Maybe someone else has your elegant solution, but it isn't me. :oops: Sorry.
jblizzle said:
You just have to add a piece of PVC pipe and then a fitting to whatever type of hose you plan to use.
Any suggestions of what hose to use for this application? I keep finding backwash hoses on "google", but don't know what fitting I should use for those.
Ideally I'd like some kind of threaded connector, and a hose to match. But there are so many to choose from ...
alanpaul said:
Pardon me, but I see the valve above the pump, and a big ole hole, but I don't see a pipe leading towards, um, a filter. :wink: Anyway, assuming it's just not visible in this photo ...
Correct, the pipe leading to my cartridge filer is directly behind this value (and thus out of frame).
Jeffrey
