Just an update - Went and tried a few things:
- Red valves OPEN, Solar CLOSED, RPM at 1400 ran without a drip on VRV
- Red valves OPEN, Solar CLOSED, RPM bump and re-prime, it had a steady flow of water out of VRV during re-prime.
- Red valves OPEN, Solar Open, Re-prime had minimal drip, definitely no steady flow of water out of the VRV.
- Red valves CLOSED, Solar CLOSED, Re-prime had no drip. As expected, no water was being sent to roof.
So now that I am getting a pretty steady stream of water out of the VRV with the solar closed during pump prime, I am going to try and remove the VRV and clean it. If that doesn't work, will try replacing it. If that still doesn't suffice, a check-valve install is likely necessary on the return line.
Will keep yall posted! If any one cares
