20x40 IG vinyl liner 36,000 gallon 20+ year old pool. Had a number of issues this year opening the pool (plus some vacation travel) and my pool is just about ready, but needs a good vacuum. Once connected, the vacuum will lose its head.
Replaced the pump motor with an exact replacement (1.5hp). Rebuilt the pump. Purchased a new vacuum hose. Still no luck. When the vacuum hose is disconnected from the skimmer, or suction side is diverted to the bottom drain, all works as it should.
I am getting a little air entering at the skimmer cuff - wrapped it with stretch wrap - but to no avail. I’m now adding water to raise the level above the top of the cuff and will try again. In the meantime - any other suggestions?
