Here's what I'm thinking:
We'll be out of town for 14 days.
I just emptied and re-filled my 16k gallon plaster pool (new pool owner). CYA currently just below 30, I'd guess 28 (using the Taylor K-2006C). Other measurements are: Ph: 7.8; Alk: 150; Calc: 320.
I'm in the southwest, plenty of sun out here. But my backyard set-up allows for relatively small direct sunlight. Seems I'm losing about 1.4 ppm FC each day. Will continue to test to verify this FC attrition. For the sake of this post, let's assume I actually do lose 1.5 ppm FC each day on average.
I'm thinking I'll bring FC up to 20 the morning we leave, AND add three 3" Trichlor tablets in the floaters. That will add an additional 10 ppm FC and 6ppm CYA. I'd set the floaters to the lowest water flow setting.
I'm not sure if when FC levels get high, the addition of tablets will have the same effect as when the FC is lower. Or, if my current low CYA levels will have an impact on FC longevity.
Recommendations to get a SWG installed, or to get that automatic chlorine pump, or to have neighbors/friends come check on the pool are not what I'm searching for. Specifically interested in the feasibility of my plan.
Thanks for the help!
