I installed a V-Green EVO 2.25 HP pump back in May. Recently I noticed the pump doesn't always start when power is applied. The green light on the pump's controller illuminates, but the pump doesn't start as expected. It is clearly getting power as evidenced by the green light. Simply recycling power starts the motor. This sporadic failure to start correctly every time power is applied makes simple power-on automation unreliable. Has anyone experienced this sporadic failure to start issue with this motor?
