Hi all, normally not one to panic too much but end of season and time to change from crazy expensive UV/Peroxide system to UV/Bleach (or even just Bleach) system and it didnt go exactly how I imagined. Left the Peroxide to run out and then converted to Bleach with auto dispenser. Next morning all blue and clear but no chlorine reading so added a 20litre drum of 10%. 1 hour later pool was green then another hour went by and pool was brown. Can still see leaves on the bottom of the deep end but definate brown. Have added another 20 litre of 10% but had to leave site with chlorine level around 5ppm.
My question is do I just need to keep adding Bleach as I would normally do to overcome a green pool or is this some other kind of problem? Should I turn off the UV?
Only have access to test strips for Peroxide and Aquacheck tru test for the chlorine here in France - Taylor not available.
Thanks for any help or advice
