Anyone have a particular UV light they would recommend? It is for a small (24,000 gallon) commercial indoor pool that currently uses bromine as the sanitizer and has issues with CC over time which I am looking to reduce. I understand it may cause a slight increase in bromine/chlorine demand, but we have a lot of bathers and I thought having a unit on a timer while bathers are using the pool would be a good idea since the pool hardly gets any sunlight (3 small skylights) to deal with the CC issue. I am also using the SeaKleer stage 1 and 2 clarifier, but it is not totally tackling the problem.
I have looked at Pentair Bioshield, Spectralight, Delta and Paramount systems. The Pentair and Spectralight seem to be more of an in-line tube and the delta and paramount units seem to be more of a "container" that the water passes through. The spectralight quote I got was double the quote for the Delta and Paramount and I am just wondering if there is any benefit to having the spectralight/pentair bioshield design vs the Delta/Paramount systems (which are half the price). If anyone has had any experience with these I would greatly appreciate it. I am not looking to spend several thousand dollars just to help reduce CC, but would like to better address the issue.
Also, would any of these units reduce the FR/GPM of water re-entering the pool? I have to keep it around 70GPM to get the proper turnover for the state and I just wanted to ask if installing one of these would/could reduce that. Probably a dumb question.
