K-2006That would add 5 ppm per day to your pool. That's high, but you are in AZ. How are you testing and what is your CYA?
I have often and just the night before. It’s always 0 ppm loss.Perform an OCLT tonight and let's rule out that anything is growing. What do you normally dose your FC to daily?
Overnight Chlorine Loss Test
Cya?I'd take it up to 60 for extra UV shielding, that's the high for a non swcg pool.
It will. You can also raise your FC to 20 right before you leave too. That and the pucks will hopefully get you through the week. Do you have any way to cover the pool? That would really be helpful. Maybe just purchase a cheap tarp at the hardware store to anchor over it if you don't have anything already.Cya?
I’m going on vacation in 2 weeks for a week and had planned on using some pucks to get me through. Not sure how many I should leave in the floater. But that should raise my cya, correct?
There are some in this area that are around 70 ppm CYA for a LC pool.I'd take it up to 60 for extra UV shielding, that's the high for a non swcg pool.
