I have this idea (maybe a crazy idea) about trying to put an “auto fill” on my AGP, only using rain water instead of my well. My current iterations of this plan involve either:
(1) A pipe plumber off my downspout to provide water to the pool and A float switch that actuates either a 3 way valve -OR- 2 single valves to divert the water either through a sediment filter and into the pool, or down the drain based on the level of the pool.
OR
(2) A rain barrel/holding tank located under my deck for the downspout to flow into. This rain barrel will have a water level activated sump pump in it that discharges through a sediment filter and into the pool. A float switch that determines the water level in the pool will determine whether or not the pump has power. So, if the water level in the pool gets low enough to activate the switch, it will energize the sump pump, as long as there is water in the rain barrel it will get pumped out into the pool. If there is not water in the rain barrel, as soo. As it rains and beings to fill up, it will kick on and start emptying the rain barrel as it continues to fill, until the pool has enough water or the rain stops and the barrel doesn’t refill.
With either choice, I would install an overflow off the skimmer so that if something went wrong with the system, it wouldn’t allow the pool to be inundated with water.
My roof is a shingled roof.
Does anyone see any any problem with this? Will I be introducing any undesirable chemicals to m water this way?
OR
