Used hot tub first steps
DIYLinerPool
80
Chicago (West Suburbs), IL
Hi All - I am getting a gently used hot tub today - Jacuzzi J-355. I understand pretty well how to maintain the chemistry, main question is when I get the spa what is the first thing I should do? Should I fill it, use ahhsome, then drain and refill? Also any tips on cleaning solutions to use to give the cover a good clean?
Thanks for the help!
Ahhsome purge. Maybe more then once depending on how much crud you get.
