So winter is upon us in SoCa, water temp running 59-63 degrees.
Ran all the tests this morning
FC=5.5
PH=7.6
TA=80
CH=350
CYA=55-60 (hate this test)
Salt=2800ppm
CSI= -0.32
I have my salt cell running at 10%, pump is running 6 hours per day at 1300rpm. Is there a point that I shut off the cell and manually dose chlorine?
Looks like TA is a bit high, but PH and TA give me a good CSI. Also when ph gets to 7.8 my csi is still running -0.14 which is good. Should I be lowering PH to 7.5 when it hits 7.8 since I can't measure PH above 7.8 and when it hits 8.0 the csi goes to 0.5.
CYA is a little low compared to the recommended numbers of FC of 5 with a cYA of 70. Should I add more or wait until spring?
FC=5.5
PH=7.6
TA=80
CH=350
Salt=2800ppm
CSI= -0.32
