Alright, I know this question has been asked hundreds of times on this site. And all of the guidance is to screw the $100s of water and just do it right...
I have a Intex Rectangle 118" x 78.75" x 29.5" (9.8' x 6.5' x 2.4', or 2m x 3m). It holds just over 1,100 gallons of water.
My pool is sitting on three 4x8 sheets of plywood. Underneath is mulch. The plywood is very sturdy. I have it semi-leveled with brick underneath the plywood, but it's very solid. All 10 feet (4 corners + 6 supports) are all sitting on the plywood firmly as well.
I measured the top flat piece of each corner to the water level and here are my variations:
9.5" Front-left
6.25" Front-right
7.5" Rear-left
4.5" Rear-right
As you can see, it has a max variance of 5". I already know the answer, I need to drain and properly level. And as much as I don't want to do that, I'm going to.
I am curious though... Being unlevel on *solid* "ground" (the plywood), am I any more or less safe than others that have theirs directly in grass?
That's really the only reason I'm asking the question, because either someone has a round pool or it's on actual ground/grass.
Your responses won't sway me one way or the other, I'm still going to level the pool. I am just curious, that's all.
I'm new to owning a pool, so I'm trying to understand the engineering and logistics of maintaining one.
9.5" Front-left
6.25" Front-right
7.5" Rear-left
4.5" Rear-right
