Re: Unexplained FC Consumption (updated title)
I have no choice but to keep my humor, although it is dwindling quickly...I honestly thought next time I am home I will just winterize and put her away for the year.
I do not have the valve on the bottom of the pool...it is 100% fiberglass shell. I do have a sump pit on the deep end to control ground water if/when I have to drain.
I have manually dosed the pool quite a few times (when home) to see if the stenner was acting up and no change.
I do have a septic system (engineered mound) but once again no sprinklers and no way for water (other than rain) to get back into the pool.
Yep my pump/filter and stenner are all on timers.
ok i confess, each time you go away i come over and pee in your pool LOL
i hope you still have your sense of humor intact
with the amount of bleach you are adding are you having to drain the pool?
if the pool is covered and not used while you are away you should have very little chlorine loss regardless of CYA
do you have an antifloat valve in the bottom of the pool. not sure what it is correctly called
i have one in mine and it was explained to me that if water pressure under pool was higher than inside it would allow water from underneath to come into pool
are you on town sewerage or septic system.
do you have one of the new treatment plant type septic systems and if so where are the sprinkler jets in relation to the pool
my latest suggestion is to manually dose pool to high level and then completely turn off pump and stenner for a couple of days and see what happens
i relly feel for you, i wish i was there to try and help in person
Do you have the pump/filter on a timer?
