- Feb 11, 2024
- 78
- Plaster
- Pentair iChlor 30
Hi, hoping this can be fixed and someone can advise me on how to fix this.
One of my 6 spa jets has such a strong water output that you can't even sit in front of it. It has no air bubbles. I only know it is on by putting my hand in front of the jet. The other 5 sputter with some weak water and weak bubbles. Not sure why it is doing this. This is a new pool build. My builder is saying we just need to add a blower, but that doesn't seem right to me, since the water output isn't uniform across the jets. Seems like he is just trying to put a band aid on this issue, so he can move onto his next project.
I have an 8x8 spillover spa with 6 jets. The spa is 110 feet from the equipment and air pipe. The air pipe is 2 inches. The pump is a 3 hp variable speed. The return to the spa is 2 inches and the jets are 1.5 inch double tee bodies. The filter is a 200 sq feet cartridge filter. There's some uncertainty in the plumbing. It seems to vary between 1.5 and 2.5 inches depending on the component.
Any insight will be greatly appreciated.
Thanks
Thanks
