Any advice/tips would be appreciated! I was losing an inch+ overnight. I had a leak detection company come out and they found a leak at the shallow end return. I dug that out and found a large leak and repaired it. That overnight I still lost an inch. I did a pressure test on that shallow end line and it held at 10psi and then slowly dropped to 3 and then held there. I put a camera in that line and nothing looked too terrible. I identified another connector in that line but it appeared intact. I then did a pressure test on the deep end line and it wouldn't hold at all. I fed the camera in that line but unfortunately could only manage to advance the camera about 18 feet but nothing suspicious stood out. Two questions. First- I am assuming because the deep end line wouldn't hold at all then there's a definite leak in that line, but with the shallow line holding and slowly dropping should I expect a leak in that line as well? Second- I'm not seeing anything dramatic on the camera. To be losing an inch still would I see a crushed pipe or something obvious like that? I know I still have another 18 feet to inspect in the deep end line but I really don't know what I should be looking for or even expect to see. I don't want to keep cutting the concrete and digging down 4 feet to find the line intact. I feel like I am playing Whac-A-Mole. Thank you for any suggestions!
