Hi. 2nd summer of Intex pool went well. I’ve almost completed taking it down for winter. Here are 2 issues I’m thinking about for next year: 1. The ground it is on was sloped so had to be dug out about 4” on 1 side, then angled to make it level. Due to this there is a gap of about 6” between the pool and edge of the dug-out ground. Not sure what to do, if anything. 2. Pool sits on 2 tarps which set directly on the ground (hard packed and level). Legs are on pavers. Tarps are about 2-3” larger than pool (16’). When it rains or water splashes out of pool, ground gets wet and dirt creeps up the outside of the liner, and also underneath. Hence, bottom of pool is dirty at closing, I do clean it well prior to storage. Any suggestions on what I can do differently, put underneath to block dirt? Or just bite the bullet and clean it. Thanks!
