- Jun 23, 2012
- 1,054
- Plaster
- Liquid Chlorine
- Pentair Intellichlor IC-40
Oh! My pool brush and Test Kit arrived today!!!!!! I'm going to study chemistry now.
later..
later..
imrodee said:Oh.. yeah, overflow. That would not be good. I didn't think about that.
The bobcat didn't make it today, so we called the PB and asked him to hold off on the plaster until that's finished. Our land is flat as a pancake, and the wind will blow all that dust on the new plaster. If Bobcat comes early enough, we could have the plaster crew come after. (That's what I'd like.)
imrodee said:Quite honestly.. The CL color could have just about any of the choices. I held it up to white paper... Thanks, I'll redo that test.
@DaveJ - OK, thanks
BTW, the PB will add "Startup TEC" when we get the water in there.
imrodee said:The CL still looks more like the 3rd block up from the bottom - which is 2 - right? I'm headed to PS, to read up more on this.
bpricedo said:You'll definitely need some calcium to protect your plaster. And that seems like a lot of chlorine for tap water, mine was like 0.8.
@DaveJ - OK, thanks
Since you have the FAS-DPD test (with the powder), no need to do the OTO (color matching) test. It comes in handy to make sure chlorine is present, but is no where near as accurate as the FAS-DPD test. Just ignore it for now and give us the FC and CC numbers when asked about your chlorine.
WILL DO!
How did you get your CL number? 11? Doesn't it go by 10 or 25 depending on sample size?
CL was 2, CH was 11. I will redo the CH. My card said it should be in the 200-300 range. I did it according to the instructions on the laminated card
There is no CYA in tap water, so don't test that again until it has been a week from when you added CYA/stabilizer. You only have a few of those tests in your kit, so no need to waste them.
OK!!
Thank you!
imrodee said:Sorry, yes I meant CH. How did you come up with a calcium hardness of 11? How many drops did it take and what sample size did you use?
Vial filled with tap water to 25 ml.
Added 20 drops R0012, mix
5 drops R0011L
Sample turned light purple/pink (not red)
added 9 drops of R0012 - water turned blue
X's 10 = 90
I didn't see that "multiple by 10" part. Seriously, I need schooling!
LOL! No, you don't need any schooling! I was very suspect that was what you had done based on your number. We see it happen often with people starting out with new test kits.
So, I am guessing that you got 90 this time and you probably actually got 110 (11 drops) the first time you did it? Your calcium is still a low, but better than 11!
Practice makes perfect on the tests!
Better?
