Have you measured your CH level? Please post the result.
Turning pink is fine, you just want to keep adding drops until the last one does not change the "pink" color, then don't count that last drop.anisudha21 said:(instruction said add drops till red, but I am seeing more of a pink tint than red, hoping that is ok)
For a cya of 35 ppm, your FC should never be below 3 ppm!anisudha21 said:The water is crystal clear and I am maintaining the Chlorine at 1-2 range.
