What a mess so far this year.
The pool opened on Saturday. Needed at least 8-10 inches of water... lowest I've ever seen it. Maybe the closers were over-zealous in draining it? Not sure. about 7 hours to get the pool filled back up and get the filter running.
I've been struggling with the filter ever since. Pressure keeps reading 35, I backwash and it comes back into the green/red zone... shouldn't it be dropping down bc I need to add more DE? I've been backwashing like crazy and can't get it to drop. Is it not washing out the DE? I don't see it at the discharge point. Had the grids replaced last year. I know every time you backwash a DE filter you need to add more DE so I've added DE a few times but not every time bc the pressure will not come down and the flow is just fine. I did put in a home warranty claim but waiting on the warranty pool company to call -- perhaps the pressure gauge needs replacing or maybe they can come clean the grids. Not sure if this is indicative of a bigger issue or not.
Now the fun.
There are so many leaves on the bottom of the pool that I decided I need to manually vacuum them out. This is the first time I brushed off the manual vacuum equipment since buying the house in 2020, and find it mostly unusable. So I got new equipment to vacuum with because my Polaris can't handle the amount of leaves alone. Problem is, I don't know which plumbing lines are which. I've been told in the past but seemingly it was in one ear and out the other. I tried turning off a line to see if I lose suction in the skimmer (I did) so I assumed that was the main drain. So I changed the valve and still didn't have suction. When I moved it to allow both pipes, I had skimmer suction. (see pics of plumbing...would appreciate any theories on plumbing). I have 1 main drain, 2 skimmers, and 2 drains in my hot tub. I can't tell what's going on.
Our salt is very low so I sent my wife off to the pool store while I vacuumed to buy a zillion bags of salt and whatever else I need to turn the pool from green to blue. They said our nitrate level is 20 and to drain the pool to 1 foot of water in the low end, refill, do it again, and then shock the pool before doing anything else. I have backwashed and added so much water to this pool in the last 5 days that now I'm concerned my hose water has nitrates and is just exacerbating the issue! Wouldn't that have diluted nitrates? She returned with nothing but a sad test result report and some shock.
I decided I couldn't consider draining the pool until I could get all the debris out of the bottom since I can't vacuum without water, and was hoping the leaves were adding to the nitrate levels. I have to return to this later today as I've got the polaris in the spa and need to figure out how to turn the main drain off to increase the suction in my skimmers.
I really don't want to drain the pool down. Are there any other options/tips for dilluting? I know chemicals can't fix nitrates.
Here are some plumbing pics if it's at all possible to remotely decipher what's what. Understanding this plumbing is half the battle. Apologies for the weeds
Now the fun.
