Ultimate Pool Seal
I used the Ultimate Pool Seal, installed it 3 years ago. After 2 years it started to soften up and I should have replaced it then. At the time it also looked expensive for what you got. It took a long time to install, making sure you applied the right amount of water, not too much, not too little. After 3 years, I had to dig it out and replace it all. After reading many reviews on line, I went back to the Original Pool Seal. I applied this product a month ago, so will see how long it lasts. It is similar but doesn't use water, it uses a liquid polymer mixed with power and put in with a supplied squeeze bottle. Then you apply a small amount of gravel over than. It gave the perfect look. Hardened up much better than Ultimate Pool Seal and was less expensive. For those interested go to http://www.[URL="http://naturalpoolseal.com"]n[/URL]aturalpoolseal.com. The web site isn't much to look at but the product is much better than the original product I tried.
