I’ve taken the steps out of the pool now. I’ll give them a scrub before they go back in!Uummmm.....you might want to scrub down those steps.
That intex pattern is always the best when showing off sparkling Gin-clear pools.
Wow that heat pump looks awesome. What temperatures are you getting your pool to with that thing?A few of the winter purchases.
1. Pump and filter combo - upgrade intex 1200gph to 0.75hp / 18” sand filter. Also needed because I got a pool heat pump
Remora FS Above Ground Swimming Pool Filter Set - AES
The Remora FS swimming pool filter set is exclusive to AES and offers a choice of six matched filter and pump combinations suitable for above ground poolswww.automatedenvironmentalsystems.co.uk
Pool heat pump - 15.8Kw on/off - Remora On/Off Swimming Pool Heat Pump with Built-in Wi-Fi - AES
Pump bypass valve
2. A pool cover reel (The intex one - had ok reviews and was only £80 from Amazon)
3. Skimmer (Ergh it’s beige. Completely missed that when I ordered. I wouldn’t order from the same place again)
4. Intex robot vac (£70 from Auto Pool Cleaner - looks like price has already gone up).
5. Boxer patch repair kit (just in case).
6. Skimmer socks (technically free because they took me over the free delivery threshold!)
Err... nothing right now, still finishing the plumbing and hopefully got the electrician booked in next week!Wow that heat pump looks awesome. What temperatures are you getting your pool to with that thing?
Seems about the going rate. 26 for me last week. The thing that worries me is how fresh it is and so whether it still is 15pct or has degraded to something lower if it’s been sat since last season. Even if you tested it I’d be surprised if you’d get much traction trying to return itI just got 20L of 15% liquid chlorine for £27 at my local pool store.
Looks great - nice job! How was gluing the flexible PVC stuff? Did it handle much like the rigid stuff when gluing up? I'm going to be doing a bit of rigid PVC myself this year, but might use the flexible intex hoses for the final connection to the pump for this year. Might want to beef that up to the flex PVC stuff next year!3 long days of working 8-9 hours (but office job) then 4-5 hours on plumbing.
I realised my pad wasn’t quite deep enough or wide enough so ended up being a harder job than it should have been.
The bypass valves also meant plenty of cuts and joins as well as my heat pump inlet being at the bottom with filter outlet up high. I also ran out of long lengths of pipe at the end so had to do a few more joins with the smaller stuff I had left over.
Only one small leak that I could see (slow drip from clear viewing backwash thing on the filter so need more sealant) but it’s wet outside anyway so hard to spot. I’ve tested the pump as I already had power down there and all good but now need electricians to come and hook up the heat pump.
