- Jun 24, 2021
- 7,512
- Vinyl
- CircuPool RJ-60
So decided I was going to convert to SWG. Bought the unit (circupool). Replumbed the entire pad. Looks great!
Now I learn that flow switch is insufficient, for safety reasons, and have to tie SWG power to the pump. NOT HAPPY. Why isn't life just easy, at least sometimes?
I want to use the programming on the VSP for the pump, not an external timer, and want to separately time the SWG, but only have it work IF the pump is on. Apparently there are no out of the box solutions for mixed equipment (pentair pump & Circupool). Had I known this would have been an issue, I would have gotten the pentair IC-60 and easy touch in the first place, instead of Circupool. If I decide to go with the Pentair combo, I'm sure I can sell the Circupool (unused at this point). Will the Pentair cell fit in the same space/unions as the circupool that I just plumbed (if I decide to go that route)? Likely won't because of the cost and the ET is overkill for a pump and a SWG only, but would be nice to know.
The solution that I did find is this current sensing relay (This Thread):
I believe the pump is 240V, and the CSR I will use is a 1-10AAC high trip. I believe, from here (Superflow tests) that this is the correct range for the setup. Can anyone confirm that the 1-10 is the right range and I'm consuming the test data correctly? (I want to run continuously at 1400, then raise to 1800 for chlorinating cycle.) Anyone else build this? Your experience? Reliability? Finally, I don't understand phasing, but from what I can gather, Amps on both hot legs of the 240 would the same, and would both be equal to the Amp draw on from the equipment. Got that right? TIA
