Newly built pool this July. I have been doing TFP since I took over from the "startup guy". He didn't do much. No CYA, no calcium, no measurable chlorine a couple days after he left. Since then, I have added things to get close to all the TFP recommended levels. CYA at 40, TA 80, CH 325, etc. I test the FC and pH almost every day and the other items about once a week. I normally test in the evening after work and I have never shown any CC. Our pool is in direct sunlight almost all day and I generally go through about 2ppm of FC per day. I tend to keep my FC on the higher side just to avoid the chance of it going below the minimum. Based on our usage, I feel like if I build to 5 then it wouldn't take much for me to end up below 3, so I tend to build to 7 and usually don't drop below 5. We have a lot of trees, but I generally fish out the leaves relatively quickly.
Anyway, I was taking my son camping this weekend, so I built up the FC to 9 since I wasn't going to be able to check it for about 2 days. When I came home today, I did a full test. Below are the results. I tested the chlorine twice because of the positive CC test. Tests from TF100 kit.
FC 4.5 (lower than I expected, but technically okay)
CC 0.75 (it had a very very slight pink after 1 drop and very clear after the second, so it is just a guess. Officially, I guess it is 1)
TA 80
CYA 40
CH 350
pH 7.6
Possible contributing factors (I don't exactly know what drives CC other than the chlorine is being used up).
I fished out all the leaves and added enough liquid chlorine to get it back to 7 (according to Pool Math, but didn't check it made it there).
Would any of these things cause a CC reading? I never let the FC get below 3, so I don't know what happened. If I test again tomorrow and it is okay, so I be fine? Or do I need to go through the dreaded SLAM process?
TA 80
CYA 40
CH 350
pH 7.6
- It has been really windy and there were more leaves and flowers in the pool than normal, several had sunk to the bottom
- Also, it is cooling off and more leaves are just falling period. The skimmer was really full today.
- There have been fires nearby and it is smoky (so bad they are cancelling activities)
- I found some fine black things floating in the spa and pool. Not sure if it is potentially ash or just new bits of tree ending up in the pool.
- I tested the water in the heat of the day rather than the evening when I normally do.
