I've been working on a complete tile/coping stone repair job since the end of last season. Last fall was all about removing the old and prepping the bond beam for the new. This season I'm adding the new material. Waterline tile is in (Laticrete 254) and grouted (Laticrete pro premium epoxy) and I'm getting ready to lay down Type S mortar between my new concrete coping pavers. They are set in 254 Platinum and have been in place about a week.
Couple of questions:
1. Is one brand of Type S mortar favored over any other or are they all the same in the opinion the the experts on this board?
2. Do the pros add any bonding agent while mixing it up and if so, what is the recommended water to bonding agent mix?
3. I noticed a comment from "jimmythegreek" on the following post (Grout for coping stones?) that read "Make sure you seal the coping first if its porous or you will have streaking where the mortar was worked in." Do you think this means the exposed surfaces, the surfaces between the coping pavers or both?
4. Any recommendations on a sealant for concrete coping pavers?
Thanks for the help. This project has convinced me that I'm only doing this job once in my life so I need done right.
