Easy Touch 4P (520591)
Does anyone know how or if it is possible to connect a Pentair 3HP Intelliflo VSF pump and a 1.5HP Superflo VS to the Easy Touch control unit? Right now I have the 3HP VSF connected with the included 2 conductor com cable to the com terminal in the Easy Touch. That makes perfect sense. I know this unit is supposed to be able to control two variable speed pumps, but I am not sure how I would hook up the 1.5HP VS with the Digital Input Cable (353129Z). This com cable is a different beast and has 6 conductors.
Is there a further expansion module that is needed, or do the pumps need to be the same? What are the requirements or limitation to be able to run two pumps independently from this control unit?
