- Apr 25, 2023
- 73
- Fiberglass
- Pentair Intellichlor IC-40
I have Intellicenter with 2 separate bodies of water (pool & spa). I hooked up both intellichlors to the data bus. Intellicenter controlled them as if they were 1 intellichlor (presumably for parallel operations). Well, I didn't want that because I run my spa intellichlor at 4% and my pool intellichlor at 40%.
I called Pentair and asked for technical advice. Pentair guy confirmed that intellicenter is working as designed and cannot separately control intellichlors with different settings. So I disconnected the spa intellichlor from the data bus. Now intellicenter software controls/reports on the pool intellichlor only. I don't see why Pentair would design a dual body system to control dual everything EXCEPT for the intellichlors. Weird design choice.
