Hello, new to this forum and really like it!
I just purchased a new Siemens QF220A Ground Fault Circuit Interrupter, 20 Amp, 2 Pole, 120V, circuit breaker to replace the existing non-GFCI 20 Amp, 2 Pole, 120V for a new Pentair Intelliflo VS pool pump.
When I opened my sub-panel I noticed there was already a GFCI 15 Amp, 1 Pole, 120V breaker installed for the pool light. The instructions for installing the Siemens QF220A Ground Fault Circuit Interrupter, 20 Amp, 2 Pole, 120V, circuit breaker require only one GFCI connect to the common neutral bar at a time.
Not sure what to do at this point as both breakers need to be GFCI. Is there a certain way to wire the two GFCI breakers together? Added a picture of the sub-panel.
Thanks in advance,
CMAC
Thanks in advance,
CMAC
