Has anyone ever heard of a TV mount/bracket that can be hung from an existing pool iron fence? Something you can hang and then unhang the TV as needed. But on an iron fence.
I think you can use the same mounting brackets as for a wall. The piece that mounts to the wall will need to be attached to the iron fence using steel brackets and just bolt it together to remain on the fence. Then the mounting piece that goes on the TV would stay attached to the TV and just latch onto the fence bracket as needed. Then just release it and pull the TV and its mount off for storage. Obviously you have to run a plug and other connections to the TV but that all can just be plugins and stored in a weatherproof box by the fence.
Buy Hangman Products S-2040A No Stud TV Hanger Mount TVs up to 55-Inch: TV Ceiling & Wall Mounts - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
My thoughts are that you have a metal straight piece that is on back side of fence you can use small u-bolts to hold it firm and at desired height. Then the TV wall bracket (that mounts traditionally to the wall) is now mounted to the metal bracket using bolts and nuts. Then the TV bracket (that screws to the TV) is unchanged and simply hangs on the wall bracket as designed.
