- Mar 5, 2020
- 2,954
- Plaster
- Astral Viron V35
I just started replying in a featured thread (Featured - How do i know if i'm generating Chlorine?), but then thought that this would go too much off-topic for the OP, and decided to start a new thread here instead. Background is the question if the SWG should be turned off during a SLAM or not. This seems to create some confusion in multiple threads, I have been reading.
I know that the Pool School mentions in the SLAM description to turn off the SWG for the duration of the SLAM. But I have also read somewhere on TFP that once you have reached shock level by adding bleach, you can use the SWG to support maintaining shock level. I can't remember if that was an older version of the Pool School article, or a different thread. I see reasons on both sides.
Pro:
Cheers,
mgtfp
Pro:
- By running the SWG you give the SLAM an extra boost by benefiting from the locally increased chlorine concentration within the SWG cell.
- By running the SWG during daylight hours for lets say 10 hours a day on 100% you would create, in the example of the above linked featured thread, 3.2ppm of chlorine. Not enough to maintain shock level during a SLAM, but it's (for the pool size in that thread) nearly half a gallon of high strength bleach per day that doesn't need to schlepped home.
- You never know exactly how much chlorine your SWG is producing, depending on water temperature, salt level, calcium deposits on the electrodes, age of the cell. That makes it more difficult to judge how much chlorine has been eaten by algae and how much bleach to add to maintain shock level.
- Running the normal, scheduled, SWG cycles that might reach into the non-daylight hours (running too long in the afternoon/evening or starting too early in the morning), you can stuff up the validity of an OCLT.
- Increased risk for calcium scaling in the cell. pH will rise due to the addition of bleach (or creating chlorine by running the SWG). Even though this part of the pH-rise is only temporary and will eventually get compensated by the different ways that chlorine levels get reduced, during the SLAM (especially on higher CYA levels that will require addition of more bleach) there will be times of higher pH (which we are blind for while at high FC), that can create, together with increased temperatures within a cell running at 100%, a critical CSI.
- Due to the hydrogen bubbles created by the SWG, there will be more CO2 out-gassing, leading to a faster pH rise during the SLAM. And this part of the pH-rise won't get compensated by chlorine being used.
Cheers,
mgtfp
