Turn over rate
To be honest, turnover is meaningless.
Read Determine Pump Run Time - Trouble Free Pool
As it does not appear you have a SaltWater Chlorine Generator, you need to run the pump long enough to distribute the liquid chlorine you add. That typically takes 30 minutes. After that the circulation time is to skim the surface to your satisfaction.
Reactions: Jujuperry
As Marty said it's a meaningless term. Depending on what needs to be achieved is how long you run the pump. If you were calculating SWCG then poolmath will give options on run time/% to meet a specific FC or close to it. For liquid chlorine, half hour would be enough. All the above is regarding sanitizing the pool water. After that it's merely preference of how much skimming and filtering you want.
