Trying to vacuum my 20x48 bestway intex above ground pool
The same way you'd vac my 14x48 Bestway pool. Plug one of the inlets (where the water goes to the pump) and attach your vac hose to the other one. If you have a through-wall skimmer, use the skimmer plate or shove the vac hose down the skimmer's throat. Or get a battery powered vacuum, which is what I have -- the WaterTech Pool Blaster. Best purchase I ever made!
