I've posted this a couple of places, but basically a just purchased a home with a 20k gallon in-ground pool. It was unoccupied since September, and the pool was never winterized. The sand filter was destroyed, but the pump and attached plumbing are functional. Now I'm not sure what order to do things in because I don't have a usable filter, and I'm not sure if running the pump with this murky water will damage it.
I'm thinking the right order would be:
Order and install new sand filter
Purchase skimmer and vacuum to remove physical debris from the pool
Get a test kit and determine chemical levels
Learn how to shock/slam/whatever to get chemicals in balance
I think this is right, but I'm actually having trouble finding a concise guide to opening a pool and a list of every piece of equipment I need. I don't want to waste test regents if I'm not in a position to actually adjust the pool to its correct levels, or test before I've done a test, or try to add chemicals if some piece of physical equipment isn't functioning. Any suggestions?
Thanks!
Thanks!
