I only have 1 suction hole in my pool (other than the main drain) and it is in my skimmer. This forces me to use a Pentair Vac-Mate to be able to skim & vacuum simultaneously, which works okay but could be alot better if I could divert some suction from the main drain to the skimmer. I'm pretty sure I have an "Anthony" type skimmer where the drain & skimmer suction join right below the skimmer hole & travel to the pump thru 1 pipe. My skimmer is missing the "Anthony Style Diverter", there's just a single hole. If my understanding is correct, the Anthony diverter screws into the hole then can be turned to decrease suction from the main drain, diverting the suction power to the skimmer. I'd just plug the main drain but whoever built the pool or replastered it did a really sloppy job on the drain making it impossible to plug it.
I think my skimmer is a Pentair Admiral, probably an older one. I've only been able to locate 3 Anthony diverter type products. 1 made by Pentair but it is short, unthreaded & doesn't look long enough to block off the drain suction. Then there are 2 products by Vap-Pak that look long enough to work. Does anyone have any insight on what brand of skimmer I have & the best way to make it function as intended?
Also, in my pic it looks like there was at one time some kind of skimmer diverter plate that someone just chipped away at to expose the actual hole below. The edges look really rough like it was busted & removed. Any help or insight would be appreciated.
